Dynatrac D44 and D60 What LCA skids will fit?
matthewd5
Hello
With Dynatrac pro rock D44 and D60 can I get LCA skids and with these do I need skids on the LCA's?
Matthew
Hello
Matthew
Did you order through dynatrac themselves or through a Vendor like ORE? If you buy it from Dynatrac they will weld stock JK brackets on for you and you can install skids that are designed for stock brackets. I wouldnt be surprised that they would/may be willing to install them for you at the time of instal. If you ordered it through ORE, they will recieve the axle with the brackets tack welded in place and can install their bracketry to the axle for you as well.
But to answer your question, yes...if you order the axle as a direct bolt on axle from Dynatrac, you will still need to install LCA skids if you want them.
