Dogde Dana 80
Stay away from any dodge axles. You could use their old kingpin fronts but they are lowpinion and passenger side drop and wont go in your Jeep. The aftermarket support for dodge axles are terrible and the newer fronts are center disconnect which is just junk. That being said do yourself and put a newer disk brake 14bolt in the rear.
If you're running big enough tires and motor, the size and weight might not be too big of an issue but I'd have to agree you might not want to go down this path if only because there isn't much support for it.
