jesse3638
With all the "odd" threads going on about DIY I figured I'd try to post something helpful I discovered. After my step son decided to bomb some mud puddles last week in the jeep while picking up his brother from school, needless to say it need at the very least a rinse. After I was finished I had water remaining in my wheels. Rather than take hours to drill holes iny perfectly good wheel I found a quick and easy trick outlined below.
Water remaining in wheel after rinsing the Jeep
Chamois AKA Absorber used for drying the jeep after a wash.
Place chamois into the wheel where the water is. I'm weird and try not to let it drip down the tire. As you can see I failed this time.
A completely dry chamois will soak up most of the water. Once full wring it out.
Finish wiping out the wheel and ensure all water is removed.
Viola! No mas agua!
I hope this helps to save someone the trouble of feeling the need to drill drain holes to remove this pesky water. I have a couple other methods I plan on experimenting with, compressed air, shop-vac on both suck and blow. I'll be sure to post a write on those as well. If I have water end up in my B-Pillar I'll also show how to remove that with out removing the entire B-Pillar.
Viola! No mas agua!
