ssgp2
After seeing the Renegate pictures, I was confused about the abilities of a small vehicle.
Found some specs
MINI ALL4 RACING
Engine N57RS12
Fuel Diesel
Performance 307 hp / 3250 rpm
Torque ca. 700 Nm / 2100 rpm
Displacement 2993 cc
Restrictor diameter: 38 mm
Topspeed 178 km/h
Transmission
Gearbox Sadev 6 Speed shift
Clutch AP Racing Clutch
Differential
Xtrac
Brake AP Disc Brakes (320 mm x 32 mm)
ventilated front / ventilated and water-cooled rear
Measure and weight
Length / Width / Height 4333 / 1998 / 1966 mm
Wheel base 2900 mm
Track width 1736 mm
Weight (empty) 1900 kg
Fuel capacitiy ca. 360 l
Body Chassis
Tyres Michelin
Size 245/80R 16
Found some specs
MINI ALL4 RACING
Engine N57RS12
Fuel Diesel
Topspeed 178 km/h
Transmission
Differential
Xtrac
Measure and weight
Wheel base 2900 mm
Track width 1736 mm
Body Chassis
Tyres Michelin
Size 245/80R 16
