Atch
Yep, I totally understand what you mean. Thanks for the help. Being that easy, I'm grabbing a few of these right now. Thanks!
You should receive a free removal tool with your order. You just slide it under the switch and pry it up.
Oh yeah, I forgot about that. :doh: Doesn't it look like a little plastic fork with only two tines?
Pulling the tops is quite easy and should not require you to take the panel off. Hard to explain in words, but the covers just basically snap on at the point that the switch rocks back and forth (I hope that makes sense). Go to OTRATTW and look at some of the pics of the rocker bodies. You should be able to see what I am talking about.
You shouldn't have to use very much force to get the cover off.
like sharkey said, its cooler where text stays lit and pic goes on with activitation, but with expense and fact that most my wires are sodored on to switches, i just left it to go on only when activated
I've picked out the ones I want on the website you guys linked and just realized that in all the pictures of the switches they show a vertical setup, including the writing. I would need them horizontal for the A-pillar RR mount, am I missing something?
Sorry, I haven't tapped the dimmer on a 2010+ interior. Pre-2010, I tapped a dimmer wire going to the hot/cold dial for the heater/air. It's been a while, but I believe it was either a brown wire with an orange stripe or an orange wire with a brown stripe.
Hopefully someone will chime in with an answer for the 2010+ interior.
Only one way to find out for sure. I'll leave the light on.
:cheesy:
