On my way to Moab my dash started to reset intermittently. It would chirp and mostly it looked like the speedo would quit and then everything would work again. Any thoughts?
not uf you have a loose ground, it'll ground then unground and reset each time. make sure your grounds ate tight and if you added any, make sure it has good contact.
I've had battery posts where the connector nut was tight but i could still twist the connector on the post.
