Thanks guys. Im guessing its the same for the front end too? with the EVO 1/4 pounder. and ill have to check CAL ranch store that we have because i dont believe there is a tractor supply around me
make sure to get daystar isolater thingys
I was debating these. are they really worth it?:thinking:
Here is mine out of kit below. They are 2 9,500lb D-Rings. I believe it's 3/4 with 7/8 pin...have to check.
View attachment 65819 View attachment 65821
I have these and you still get rattle between the shackle bolt making contact with the bolt hole on my bumper. Honestly, if noise is an issue take them off and stow them away in your Jeep and pull them when you need them.
I ran a layer of black electrical tape around the bolt no noise or rattle. ...
i bought 3/4" from tractor supply. i got the black 14,500 pound ones. the cast ones are 9,500 pound. you can fit the 7/8 ones, but i think you have to drill out the hole or dremmel it out a bit.
