D-rings. Do you leave them on?
I don't see a point in leaving them on all the time. Lock them in the center console if you're worried you'll get stuck driving to work. Then you'll have them but it's that much harder to be stolen. I don't need to be loaded down for a 13 year excursion across an African desert to go to work though. :twocents:
Quick question, what size d rings do you all use on the evo d ring mounts in the rear frame rails?
Here are the 7/8" with the rubber Daystar washers on there to stop rattles. I had to cut the holes in the washers bigger since they only are for 3/4" but they work
