And you leave it connected all the time ?
Oh yeah, the factory rear swaybar won't limit your travel - trust me. As you can see in the pic below, this is our JK at a full flex and limiting straps are taught.
Oh wow ! Well now I know thanks for the info. In This photo are those long arms ?? I can't tell
How are those with a coilovers set up ? Cuz I want coilovers , just not enough coin for evos long arms
They're great. We ran like that for over a year. ChrisB is running the bolt-on setup with minimal adjustable short arms now and I'm sure he'll tell you the same.
No, this shot was taken back when we were still running Full Traction short arms. We are now running EVO MFG long arms.
Is the ride as comfortable as long arms tho ?
I run a rear antirock and in a two door I get a lot of rear sway on the freeway. Also in a two door with a rear antirock it seems like it takes up more room when flexed. What I mean is when one or other rear tire is stuffed it forces the rear trackbar to push rear end closer to sway bar and closer to inner rear tire sidewall.
I currently am running 4.5 backspacing plus 1.5 wheel spacers to avoid my rear antirock to push into my rear tire sidewalls when flexing.
Plus I redrilled my lower links up higher and using the longest adjustable link I can find in the rear.
Are these the "ultimate" control arms ???
Ride comfort is subjective. When we were running this setup, I thought it was the best. Sure, with long arms it's better but, I wouldn't have known that had we not upgraded to them.
One of the reasons why we aren't running one in the rear and we have a 4-door.
Yes, these are the Ultimate control arms but, if you plan on running coil overs, I would recommend Currie Arms instead as they have Johnny Joints on both end of the links. Bonded rubber bushings are nice, quite and require no maintenance but, they cannot handle the amount of flex EVO coil overs provide and they will blow.
It rides awesome, it's smoother than a long arm with normal coils and shocks. Superior in the desert as well.
I suggest going coilovers first, then long arms. You get more for your money, flex and ride quality.
So if you were in my shoes, would you wait and dish out the extra 1000bucks or so for evo long arms or get currie short arms and call it good ? .. With Intensions of running c/o
What he said. :yup:
I would get the bolt on coil overs and just the arms I needed to dial in my ride. When you can afford it, you can upgrade at that time if you feel the need for it but, I doubt you will.
Just run front lowers until you can afford long arms.
Or what he said.....
Okay wait ... So front lowers with the other arms still being the factory arms ??
Yes, on the 4 door you can get away with all factory arms except for the front lowers. You need them to adjust caster.
What about a 2 door cuz That's what I have ?
You will need rear uppers as well. The pinion angle is too steep on the 2 door.
