No. Plug welds would fill in the three holes.
I was asking a rhetorical question. I believe those holes are as a bolt on option. Personally, I went with weld on, just to be sure.
They are NOT a bolt option. They are plug weld holes. Similar to how the rear diff housing is set up
Thinking it's time to get some EVO Sliders and maybe a set of Skins. I have a 2 door Jk and while I will likely order and paint myself I do not have the ability to weld or a welder for that matter. My plan is to try and find a shop around Reno or Carson that can do the installation but just curious as to how much you all think it might cost to have them installed? planning on calling around but I don't have the first clue of a welder labor rate and don't want to get bent over. Anyway want to see what the total cost might be around before I fully make my decision at this point. thanks in advance
The reason I asked is because (in my personal opinion) plug welds alone doesn't seam strong enough. On the other hand yours seams to support a whole other problem. Now you have access for moisture to get between the slider and frame, and with a continuous bead there is no drainage. I would have to assume that they should be plugged as well.
Both are supposed to be welded...the plug welds and the edge not just the plug welds.
I'm pretty sure the intent is to plug weld the holes, not to say you couldn't bolt them on there. Having those holes not filled could lead to rust.
^This. EVO sliders are NOT supposed to be bolted on. I have no idea why they didn't weld the rosettes.
I am curious about these comments. I wonder if maybe there was a change from Generation 1 to Generation 2? Here is a photo I found from Eddie:
These were taken quite a while ago, I suspect back in 2009 or so and this would likely make then the 1st generation, no? Now I do not see any holes on the mount plates/feet in the photo above. I find it hard to believe that Off Road Evolution would not plug/rosette weld those holes and not have a valid reason. We just don't know why. So you guys are absolutely sure that those holes could not be used to bolt on the sliders? Of course, it would be WAY better to weld them on, I agree and that is specifically why I had ORE do the work, but to say that those holes are ONLY for plugs welds is a bit extreme, don't you guys think?
They are 100% weld-on sliders ONLY...pinkie swearbut to say that those holes are ONLY for plugs welds is a bit extreme, don't you guys think?
Yep, 100% weld on and the plugs/rosettes get welded WITH the perimeter.
None of us are saying the rosettes are to be used alone.
I can all but guarantee there is a thread on here somewhere where EVO makes it crystal clear they are rosettes and not bolt holes.
It's not going to change the strength of your sliders by any real amount, but I would suggest either throwing some silicon in there or something else to fill and seal the void.
