A few things
Finally had a chance to get some pics of some of the new stuff. The biggest thing was I had the frame mostly straightened.
It was weird, but while they had it on the rack and had everything set up after making the pulls, the frame was perfectly level according to the targets.
However, the driver front still was dipped down noticeably, yet way better than it was. The best we could figure was the problem had to be in the suspension since the frame was good now and the body was straight to the frame. The front frame horns are still bent up slightly causing the front to sag down. They didn't want to make any pulls there
until we figured out the suspension issues. I thought maybe the spring bolts could be too tight and held the spring in a sagging position after the pulls so I loosened and retightened and that didn't do much.
I want out on a limb and guessed it could be in the springs and swapped the fronts from right to left and and vise versa and suddenly it was perfectly level all around.
Now I need to finish the frame straightening but I will probably wait until Jan. or Feb. to do that.
Since the frame from the front bumpstops back is good, I installed the rock sliders which I still need to powder-coat. Also picked up a Procomp rear bumper and Rockhard Front bumper.
I replaced all the hinges finally. The Crown windshield ones were junk and didn't fit at all. Got some Kentrol ones and they were perfect. All the other stainless on the outside was fine.
Now it's time to concentrate on the inside. Got a new brushed stainless dash panel. Went with black accent parts for that and already have the gauges and wiring as posted previously.
I also have a pair of 6" round KC Daylighters with a wiring harness in stainless for those windshield brackets coming in maybe next week.
This will take awhile but hopefully will be fun.
After all that I will move onto the final phase, the drivetrain and exhaust. Plans on that are a cleanup, gaskets and painting of the engine along with a small assortment of upgrades. Then axle refurbishing and a rear drive shaft.
maybe I'll be driving it sometime late 2019-early 2020. We'll see how it goes.
