JeepDrum New member Dec 31, 2015 #41 H8ROADS said: There's several people that make a bracket as well. Click to expand... Yeah I know. I just like making my own stuff when I can. I probably have stuff lying around to do it.
mo0s3 New member Dec 31, 2015 #42 Adrenalinemasher said: From what i can tell the rugged ridge one seems to require that i drill two screws into the plastic up there. If that's incorrect then that would be awesome and ill just order that but it sure looks like you do. Click to expand... No drilling required
TLW1022 New member Jan 1, 2016 #43 JeepDrum said: That looks nice! What did you use as insulation around the footman loop? Click to expand... 2 - 3/8"Rubber Isolated Clamps, (cable TV section in Home Depot) 2 - 1" L Brackets 4 - 10-32 x 3/8 Bolts, nuts & washers Total cost @ $7
JeepDrum New member Jan 1, 2016 #44 TLW1022 said: 2 - 3/8"Rubber Isolated Clamps, (cable TV section in Home Depot) 2 - 1" L Brackets 4 - 10-32 x 3/8 Bolts, nuts & washers Total cost @ $7 Click to expand... I'll have to check out the clamps. Thanks!
tkd415 New member Jan 5, 2016 #45 CB Radio Mount on Jk I screwed the cb bracket right into the plastic
