GuahanJeeper671
I have a 2.5 rubicon express lift kit with Barnes 4WD drop brackets and stock control arms I was wondering would cam bolts help more with the geometry and if so which one is best recommended?
What are you trying to correct?I have a 2.5 rubicon express lift kit with Barnes 4WD drop brackets and stock control arms I was wondering would cam bolts help more with the geometry and if so which one is best recommended?
Caster and pinion feels a little like it still wants to wanderWhat are you trying to correct?
what tire do you have and at what pressureCaster and pinion feels a little like it still wants to wander
You really should be running closer to 30 psi. Too much air with new tires will make your Jeep feel flighty.Toyo R/T Trail 315/70/r17 at 35 psi
Up front, caster takes precedence over pinion. What is your caster at now?Caster and pinion feels a little like it still wants to wander
Not too sure will check it thoUp front, caster takes precedence over pinion. What is your caster at now?
Crazy part about it is the tire shop set it to 42 psi then dropped it to 35 when I got home right after but I will drop to 30 and see how that goesYou really should be running closer to 30 psi. Too much air with new tires will make your Jeep feel flighty.
Factory is about +4°. I would NOT exceed +6° and even that is a bit much and can lead to driveline vibrations, especially if you have a JK or a JL without FAD.Not too sure will check it tho
Well both upper and lower are pretty close to parallel right now so I’m assuming it’s probably close to stockFactory is about +4°. I would NOT exceed +6° and even that is a bit much and can lead to driveline vibrations, especially if you have a JK or a JL without FAD.
Sorry about the glare don’t know if you can see thatWell both upper and lower are pretty close to parallel right now so I’m assuming it’s probably close to stock
You need to measure it with an angle gauge.Sorry about the glare don’t know if you can see that
this, I have the nitto equivalent and they do better at 30psiYou really should be running closer to 30 psi. Too much air with new tires will make your Jeep feel flighty.
