C gussets
Clowe
I think that I already know the answer, but do you think that my gussets are bent. I noticed my tires leaning in, but I haven't checked the play in my ball joints yet. I am fearing the worst.
Sent from my VS990 using WAYALIFE mobile app
Looks like Camber issue, however toe angle being off can create a visual illusion of a camber problem. I would check that first. If toe is good, buy a ProRock 44. :D
I want one, but not in the budget for a while. Well just checked and no play in the ball joints. I'll have to check the toe. If it is the gussets is there a fix that will be save for a year or so?
Looking at your pics, you don't have gussets, if your inner knuckle (C) is bent, I would recommend rotating your tires every 1500 miles or so to make them last longer until you replace the Axle.
