Bump stops
Dopey84
So I just upgraded to 35s and am curious what size bump stops y'all are running.. my set up is evo leveling kit, chopped fenders. And 35x12.50 18LT... tires are used mileage unknown and measure from ground to top shoulder edge to 33 1/2.
Only you can determine the size you need by cycling your suspension to full bump.
True, cycle your suspension. But...
I'm on the same suspension/tire size (except mine are 17's), and am using one hockey puck on each corner. So far, zero rubbing.
Overall "build thread" http://wayalife.com/showthread.php?2...ker-quot-build
I was contemplating using picks just wasn't sure if it would be enough as I don't want to fully compress my springs.. but I will cycle to full bump and measure from there
Typically, you need as much bump stop extension as you have lift. Being that you just have a leveling kit, you can probably get by with just running the factory bumps.
Not exactly. As I have mentioned, you typically need as much bump stop extension as you have lift. The primary point of them is to help prevent the over compression of your coils and them limiting things like rubbing is just a perk.
So I went out and fully cycled and compressed my suspension and there was no need for bump stops the stock ones are sufficient enough.. thank you everyone for your help and input
