I use that spray.. for flux core wire... do you need it if running gas?
Just flux core. With gas, you should be fine without it.
Oh baby. Shits about to get welded so wrong.View attachment 360776
Sent from my SM-G996U using WAYALIFE mobile app
Yeah, picking up a tank Friday. I was just excited to try it out and had flux on hand.Nice! ... it has the word "PRO" in it... so you should be good. Lol.. Are you using FluxCore?
This is sitting at ride height and I still cant get bolt in through backside so I tried a smaller bolt. The lower I droop the worst it covers eachother. Also if the lower control arm rotates to its left the bolts bind up on eachother at droop. I have the lower arm twisted as far right as it can go in this picture.
Looks like the only option is to drop arms to get bolt in and even grind a little off each head to assure clearance.
Thinking about cutting off pinch clamp off a-arm and moving backwards so the bolts don't aligned with each other.View attachment 360779
I'll try and give ORE a quick call and see if they recommend that. I did that on the stock and pr44 axle but didn't think it would be needed on 60s. That would definitely fix the problem.A set of shock relocation brackets might do the trick
http://evomfg.com/EVO-MFG-Products/Wrangler-JK-JKU-2007-current/Suspension-Components?product_id=213
ETA: They might make the shock sit a little better too
Congrats. Glad that saga of bs is behind you. Those are bad ass! Movin forward beats the hell out of keep waiting. Glad everything finally worked out.The day has come!
Man am I so happy I told DT to pound sand. These UDs are massive. Moving them around ain't to bad.
View attachment 360727View attachment 360728
