TrailHunter
Re tube was only $200 for me last year.
You don't need a whole new driveshaft if you already have a good one, just get it re tubed to the right length.
Cool! That's not bad.
I didn’t have this issue when I got my PR44.
Perhaps the shaft was too short from the get go.
So I thought the tooth being off was the issue. I made sure the front shaft was on the correct marks, reinstalled, torque to specs, checked pinion angles, took for a drive and vibrated like a SOB from 60 and up.
Recheck everything and came across this. Is this normal?
https://youtu.be/P64kLYs0aDo
Sent from my SM-G986U using WAYALIFE mobile app
No need to brag about your shaft length...
Lol right!No need to brag about your shaft length...
Just took it for a test drive still have vibration. Pulling it off and going to the drive shop.
I have. I changed the pinion angle then through the shaft back on took it for a drive and vibration was still there 60 to 80 mph. Came back home topl the shaft off, took her on the same test drive and zero vibration as fast as a Jeep can go.You should drive it without the front ds and see how it is
Took it to the drive shop they said I need to add an inch and a half to it. Two hundred bucks and I'll have it back.
Hopefully thats the end of this issue.
Awesome! Glad you were able to get it worked out.Alright, got the shaft back today and vibrations are gone finally.
