Fishfam_jku
Been a bit but can’t find my answer anywhere yet.
This weekend went ahead and replaced my Brake Booster and Master Cylinder. Stock MS leaked and ended up killing my booster diaphragm.
Things went relatively smooth. New Booster holds vacuum. The new MS was bench bled as best possible. Install seamed to go well. I knew I had some air in the lines due to a squishy pedal, not too surprising. Went through and did a standard bleed through all four corners and was able to pull air out. Pedal felt good, so I check for leaks and buttoned it up for a test drive.
Made less than 1/2 mile before my brake pedal got stiff, only 0-1” of movement. By the time I made it a mile I knew I had an issue. Very touchy brake pedal and was having to give it some gas just to keep speed. Both front rotors are dragging. Pulled into a parking lot, sure enough, both front were locked up. Not wanting to risk it, I depressurized the brakes by a quick bleed in the parking lot, which thankfully is the same lot as our local 4x4 Shop. Drove it through the parking lot and left her there.
Now my assumption it air in the ABS system but this is new area for me. I don’t have the reader capable of ABS bleed. Anyone ran into this one? Am I missing something?
Cheers
Cheers
