Guascone Member Apr 21, 2017 #1 Hi, has the front and the rear brake line, the same length and connections ? I would like to install the new line, which length do you suggest? I'm istalling a 3.5" lift with long travel shocks. Thanks!
wayoflife Administrator Staff member Apr 21, 2017 #2 From the factory, they are not but being that you're installing aftermarket lines, you can get away with installing ones that are the same length. Here's a write-up that should help you out. http://wayalife.com/showthread.php?...eel-Extended-Brake-Line-Installation-Write-Up
Guascone Member Apr 21, 2017 #3 Thanks a lot! I will follow your suggestion! Sent from my iPhone using WAYALIFE mobile app
Andy5160 Hooked Apr 21, 2017 #4 I am about to follow the same write up. I opted to go with Rancho lines.
