Brake Line Extension Install
Zevulin
Question about adding brake line extensions, does it make a difference if I add each extension and bleed as I go, or add all the extensions and then bleed them?
Thx!
Thx!
You could probably get away with that but it'd be best to swap them all and then bleed in the correct order to make sure you've got all the air out. Rear passenger, rear driver, front passenger, then front driver.
