bruggymonster
I've seen these speakers on a wrangler before and I think it'd be a sweet project for this summer. Does anyone know which ones work best or how to mount/ wire them?
I have a local friend that did this with his JK. I'll see if I can get some pics from him for you. I do know that the ones he used are very easily removed if he needs the space.
That's awesome! Thanks!
You looking to mount yours to the rollbars? My friend has his attached to the inside of the rear tub as his ride didn't come with a sub woofer. He's on his way home right now but said he'd grab a few pics later today. I'll post them up when I get them.
Yeah I was thinking about using something like this on the roll bar and feeding the wires under the fabric. View attachment 133919
That would probably work, but the setup my friend uses has the wire harness/plug incorporated into the quick disconnect so they are really easy to remove without having to mess with the wires each time.
Ok here's the pics. As you can see, the plug is actually part of the mount. He simply loosens the set screw to remove the speakers, no wires to mess with. View attachment 134030View attachment 134031View attachment 134032
So did he just feed the wire through the mount? And then how did he attach it to the actual tub?
