sandyhicks
I have always went to larger calipers with more pistons when I used larger tires and wheels on my Harleys. Dobyou upgrade the brakes for the heavier tires?
only time I changed brake size was on my 2010 JKU, 37s on beadlocks and regularly hauling a loaded 5x8 trailer. I upgraded to the Dynatrac Pro Grip kit, larger rotors, caliper brackets to fit the larger rotors (brackets only) and all else was stock, calipers, booster and braking was great.I have always went to larger calipers with more pistons when I used larger tires and wheels on my Harleys. Dobyou upgrade the brakes for the heavier tires?
Six piston calipers on the 392??How large is larger? I run 38s on my 392 and feel the factory brakes work great.
The only thing I’ve counted the piston calibers on is my mountain bike. Stock works great and is still the best replacement when they go out.Six piston calipers on the 392??
Not sure what you’re driving but if it a JK then folks usually upgrade the booster. Either the J8 or, a booster from a 2017 has a slightly bigger bore and that helps a little. Some people leave it and they don’t mind.Wasn't thinking , you do upgrade to bigger brakes with Dana 60 and 80 by default.
