I've run into an issue following the axle shaft replacement write-up. My son and I cannot get the rotors off on either side; they appear to be rusted in place. I tried using my 5lb sledge all around the rotor without touching the braking surface. I sprayed a ton of PB blaster in the log bolt holes and the center hub.
I got the four rear nuts off to remove the axle shaft, but it won't come out and since I cannot remove the rotor, I'm unable to pry it out either.
I was going to replace brake pads only while replacing the axle shafts, but it looks like I might need to beat the actual braking surface from behind to get these off. Any other suggestions?
I've heard about tapping two 3/8" holes into the rotor and inserting a 3/8" bolt to get the rotor to pop off. Is that something that might work in my situation?
I have no problem replacing the rotors if I need to, but I need to get these axle shafts off! :doh:
Thanks!
Thanks!
