The bottom end of my original tensioner blew out its bushing
damn, that's pricey now, $222 for mopar on amazon
I would think the OMIX one wouldn't hurt, but also that the Mopar one still isn't too much more.
It wasn’t fun, I had to tap the end of the broken bolt and work it out of the block with the tiniest screwdriver… And then eventually realized the tensioner’s lower mounting plate could be removedThis is where I’m at as well.
That’s crazy yours failed so violently. Definitely don't want that.
It wasn’t fun, I had to tap the end of the broken bolt and work it out of the block with the tiniest screwdriver… And then eventually realized the tensioner’s lower mounting plate could be removed![]()
Not that I can remember. The plastic bushing for the lower bolt was toast and I think it was pulling up against the bolt rather than rattling around loose, if that makes sense.Haha, keeps you sharp working out of position though!
Hey was yours making a mean rattling sound before it grenaded? If i put pressure on the bracket while the engine is running, the noise goes away…
Which one did you go with? Mopar or OMIX?Swapped out the old.
Bushings definitely loose, worn.
Pulley is loose, noisy, doesn’t spin very long.
What surprised me most was how much more resistance the new spring has.
Was shocked at how worn the old spring was…
How hard was the install? I'm in need of replacement of that or idler pullies or both but really haven't done too much investigating.I waited too long to decide and ended out going omix because I didn’t want to wait for shipping on the mopar.
Omix seems sturdy enough. Would have liked to support a non-China country of origin, but I needed the part now, so…guess ya can’t win em all.
Glad the rattling is gone. Shit sounded close to the end of days…
It's not too bad, you can do it without removing and rerouting the whole belt too. Tensioner has a 1/2 inch inlet in the center so you push against the tension of the belt. I used a breaker bar for more leverage. And repeated after tightening the new one down.How hard was the install? I'm in need of replacement of that or idler pullies or both but really haven't done too much investigating.
What he said. I didn't even remove the alternator for my idler pulleys but I guess it depends on how fat your fingers are... LolDefinitely go for it.
Tensioner is 2 bolts. All you have to remove is the air intake to get to it.
Then, idler pulleys are like 12 bucks at the auto store.
Can remember if you have to pull the alternator bracket to get to them.
Thanks to you both. Probably need to set aside some time this week to look at it. I was thinking I may have to pull the grill and radiator to get in there. That pic helps a lot. Also I wear a size medium glove so I don't think fat fingers will be an issue...haha.What he said. I didn't even remove the alternator for my idler pulleys but I guess it depends on how fat your fingers are... Lol
remember to place the belt on the correct side of the tension idler before tightening it up, looks like enough room to squeeze the belt thru if you don't, but that's a big no.Thanks to you both. Probably need to set aside some time this week to look at it. I was thinking I may have to pull the grill and radiator to get in there. That pic helps a lot. Also I wear a size medium glove so I don't think fat fingers will be an issue...haha.
