The advanced class kids delete or bypass the AUX, because it's notorious for crapping out and taking the the main battery down with it.
The batteries are parallel except during ESS events, so if one begins to die, it is free to start sucking the life out of the other. A situation that has left many high and dry.
It's an emissions reduction feature to appease the EPA and get a slightly better MPG rating on the window sticker.
Some people disable ESS with a Tazer, but unless you break the physical link between the two batteries, you're still at risk for it dying and taking the main down with it.
At any rate, do what works best for you. Mine has been offline for over a year and zero issues. ESS still works off the main battery, on the rare occasions when I overlook hitting the button.
It takes maybe ten minutes to put back to factory setup if I need to go in for any warranty services.
Same with the catch can
