You can view the page at http://wayalife.com/content.php?66-Tuffy-Security-JK-Overhead-CB-Console-Installation-Write-Up
What you don't mention is how you route the antenna or the power to the radio. I realize it's possible to follow the sound bar to the side and probably down the roll bar to the floor, but where is the antenna itself mounted (especially if you're a soft-top) and where are you connecting to power? I'm going to assume (a big mistake usually) that you're using one of the direct battery connections (inside the cabin?) but this added info would be helpful.
