Will the EVO co work with the Artec truss ?
I think he abbreviated Coil Over with the little co
This truss would be a great way to strengthen my axle without breaking the bank.
You do know that with coil overs, you will be able to drive a lot faster across the desert and without realizing it, right? It is this speed more than any rock crawling you can ever hope to do that WILL bend your front axle EVEN WITH a truss installed. The bending WILL happen at the point where the axle tube meets up with the differential and I have seen it happen. I'm pretty sure it just happened to a member on this forum as well. If it were me, I would recommend that you just play with what you got and save up until you can afford a real solution - a ProRock 44. Me, I was able to get about 60,000 miles out of my 2012 front axle before it finally needed to be replaced. Of course, that's just my opinion - just trying to save you some money.
Thanks for the info , yes I meant coil overs . I would love a PR44 but its not in my budget right now or any time soon .
I run the artec truss with Evo bolt on c/o. I did it because my buddy is a good welder so it was pretty cheap to do(truss cost and whiskey). I wouldn't pay a shop to do it, some of the quotes I got just see what it would be, it was almost half the cost of a new prorock.
I think it also comes down to what tire size you are running. Anything bigger then a 37" and your flying through the desert. It would be a waste of money to truss a stock axle. On the other hand if your running a 37" or smaller tire and you sleeve and gusset a stock 44 you should been fine! That being said everything is relative to your driving style as well!
Of course you know what they say: assumption is the mother of all f- ~* ups! If you were to use RSE inner and outer sleeves you will increase the strength of your axle by 55%. So unless your chucking your jk 20' in air off the side of a sand dune, the axle will hold up fine! But I know the are some people out there that like to do those kinds of things!
oops, i thought he meant evo company :crazyeyes:
