Overland_stormtrooper
I'll have to give this a go didnt know it could be done so thanks for this infoThere is a way to calibrate the temperature reading to more closely match the inside temp. This info is easily googled, but here's the basic:
You simply hold down the plus (+) and minus (-) buttons together for 5 seconds until AOF appears in the display. Now adjust up 6 degrees, or down 6 degrees. Once this is done it will stay in permanent memory until you readjust. I did this to mine so I can set it at 34 degrees, and it stays right above freezing. Enjoy! [emoji106]
Sent from my SAMSUNG-SM-G891A using WAYALIFE mobile app
