Jkzinger
Wondering if anyone out there has had this issue with their ARB fridge.  Mine does not want to run at the medium/high setting for the automatic sensor that senses battery voltage.  When I turn it to low (which will drain the battery to a lower level before shutting off) it runs ok.  I have tried it in both my JK and Grand Cherokee with the same results.  I checked my voltage drop from the battery to the power plug to the end of the cord where it plugs into the fridge and there is virtually no loss of voltage.  Also,  cleaned it real well and checked all wires for a loose connection.
It also seems sporadic on how long it wants to run before giving me the red "check" light. Anyone had this happen to theirs?
Also, has anyone had one repaired anywhere? Mine is still under warranty, but it sounds like you need to ship it to get it fixed.
Thanks,:thinking::thinking:
