Airing down
I am running 35's on standard rims, how low an air pressure do people recommend I go to safely without risking popping a bead?
Depending on the terrain determines how much you should go down. I've got all the way to 8 without issue. I'd play it safe around 15psi
Based on your location, is it safe to assume you'll mostly be playing on sand? If so, you should be okay at about 10 psi and that'll give you a nice footprint to have some fun on.
It really depends on the tires your using. A stock jeep tire, I wouldn't go more then 15psi, a 12.5" mud tire, I would take it as low as 10psi.
I run 8 in the rear and 10-12 in the front mostly slow speed east coast tight trails through the woods. Higher speed stuff I would go 12 in the raer and 15 in the front.
15 psi works for me on the east coast. Was a little nervous putting a tire that low for the first time off road it but after wheeling it at 15 I wouldn't hesitate to go lower either.
I am running the Stock rims and Stock BFG Mud Ter and I aid down to 15 most of the time. Never gone below that
