Abs esp tcs lights all came out.
Im assuming you mean theyre on. And ive learned from experience they will come on if your steering wheel is off center
I have a JKU and all my lights came out, abs esp tcs. What can I do to fix this ? JKU 2008.
I forgot the name of it but when this happened to my bros jeep it was a sensor in the wheel area, someone on here will know the name
I would vote for a wheel speed sensor. I had a wire get cut to one and had the same symptoms you are describing on my 14.
If you have a way to pull codes, it should point you in the right direction.
The infamous JK light show also started occurring to me after doing some electrical work. Turned out i hadn't reattached the battery cables particularly well and one was wiggling around enough to cause a whole myriad of issues. Check those connections!
As mentioned, a loose battery cable will cause ALL your lights to come on and off. This is common on 2012-up especially if you've tried attaching additional leads to the battery as the clamp uses a tappered nut to get it on tight. Otherwise, a bad wheel speed sensor will do this as well.
Putting your jeep on a lift and spinning the tires will do this too. Just saying. ;) :cheesy::cheesy: We were able to help in clearing the code(s) by also using the procal.
LOL!! yup, on a 2012 and up, this is true as all 4 wheels need to spin. If they don't, the speed sensors will throw a code.
