Got the new trans in tonight, still need to come up with a new th400 to dana 20 adapter, they seem to be rarer than hens teeth. Also did some finish welding on the sliders. I need to move the rear kicker on the drivers side to match the passenger side. Yes the driver side slider is kicked up a bit, thats because after years of me beating on it the frame is slightly tweaked. The floor to slider height is the same on both sides, i did this to help the tub sit level and offset the dreaded jeep lean.
Sent from my LGLS991 using WAYALIFE mobile app
Theres very few that dont lean. The dealership fix in the 80's was to put a shim between the spring and axle on the high side to lower it down even with the low side.
You cant shim it up because the springs run under the axle. Putting a shim in the low side would lower it further.
Yeah, ive seen the pictures of yours. It looks killer, i would love to have one that nice to run the roads in. Mine is cobbled together with junkyard parts from about 6 different vehicles. I have a 60 cj5 that i hope to roll into the garage soon, and take back to factory condition. If i ever get it done ill have both ends of the spectrum. A clean stock early 5 and a stupidly modified 7.
