desertrunner
So I'm finally getting the rear locker and gears installed from my trail leader package order. The shop called me with an issue saying I have a locker for the wrong gear ratio and that the ring gear bolts won't fit into the locker.
I told them that due the D44 rear having a thick ring gear it needs to be the 3.92 and down carrier even though I'm getting 4.88s so the real issue is the ring gear bolts are too big to fit the locker.
I called dynatrac and they quickly told me that typically you have to drill the holes of the locker bigger to make the ring gear bolts fit.... makes sense. The shop didn't like that answer too much though saying that ARB won't warranty the locker if they do that. So has anyone else had to drill the locker holes bigger with the 35 spline rear ARB? I would imagine so with how dynatrac answered it so quickly/ should I be worried at all about the possibility of ARB not warranting the locker or just tell the shop to drill the holes bigger and go?
