Very nice I would love to hear your review of the upgrades after you hit some trails and on road ride. Definitely looking at getting lift and larger tires for my rig also just so many choices and tough for me to make a final choice.
Took it out to Johnson Valley for KOH this weekend. To be totally honest I was not impressed. Pretty bummed for the amount of money I spent on the Enforcer Stage 3 lift. Coil overs are ridiculously loud. I put in some heavier springs. Not sure what they are right now but basically 50lbs heavier on all 4 corners since I have a tire swing, 37” spare, Steel bumper, winch etc.... Suspension was very very very stiff. Spent a couple hours in the whoops trying to break everything in a bit. Front shocks seem to be ok. Much quieter and smoother than the rears. Rears got louder throughout the day. Got home and looks like I got into the bumps pretty good. Anyways, now looking at AGM sliders. Another $450*
I’ll try and contact EVO on Monday to see if I can get any advice on the shock setup. If not, I’ll have to find a shock tuning expert. I expected the shocks to be much closer considering it’s a “bolt-on” kit.
Decided to move back to the stock springs, install the AGM sliders, clock the springs and pressurize all shocks to an even 150 lbs of nitrogen. Shocks were different pressure from EVO. Not sure why.
Finally added the AGM sliders, what a difference. Also checked and charged shocks to 175 which also made a noticeable difference. All were at different levels from evo. Range 115-140[emoji4]
Thank you [emoji1317]Just the type of info I was hoping to get. What springs are you using? Stock springs? What’s your pre-load set at? How many inches down is your pre-load ring from the top, front and rear? How far are your stop nuts above the slider? What’s your lift height? EVO says anywhere from 3-5”. I prefer closer to 3. 3 puts the shock very close to bottoming. If I can remember right I’m 2-3” max from bottoming. [emoji1304] What size tires you running? What Bumper? What tire carrier? What sliders and fenders? What front bumper? Winch? Trying to get a sense of what type of load you typically carry. Thanks again!
Dammmm. Let me publish a novel real quick lol. I’ll get started on the in a few. Rotating tires right. Now.
