Speedy_RCW
Well guys, with the baby right around the corner I figure the Jeep may end up sitting in the driveway even more than it does now. Thought it would be a good time to let it go while we decide on the next toy/build. Asking price is $38k. Let me know if you have any questions.
2015 Jeep Wrangler Unlimited Rubicon
Hard Rock Edition
68k miles
Well taken care of. Religious oil changes with Mobil 1 Synthetic at 5k miles. I bought this brand new and hate to see it go. I may be missing some things but the highlights are below. I also have a bunch of spare parts to throw in with it including full set of driveshafts, steering box, rear axle shafts, etc. Clean title in hand.
Front Axle:
Dynatrac ProRock 44 Unlimited Housing (1/2” Thick Tubes)
Synergy weld on raised trackbar bracket
ARB 35 spline air locker
G2 35 spline chromoly axle shafts
Motive Gear 5.13 Gears
Dynatrac ProGrip brakes
Stainless braided brake lines
Dynatrac ProSteer rebuildable ball joints
Custom DOM tie rod with 7/8” heim ends
Adams 1310 HD Drive Shaft
Rear Axle:
Stock D44 housing
Ten Factory Chromoly Axle Shafts
Motive Gear 5.13 gears
Dynatrac ProGrip Brakes
Adams 1350 driveshaft
Wheels and Tires:
5- 37x12.5 Nitto Ridge Grapplers (less than 5k miles on them)
5- 17” ATX Slab beadlock wheels
Suspension/Steering:
JKS 3.5” Springs Front and Rear
All 8 control arms are JKS J-Flex adjustable arms
Fox 2.0 shocks
Synergy Track Bar
Synergy Drag Link
PSC Big Bore HD-II steering box
PSC upgraded Power Steering hoses
Exterior/Protection :
Smittybilt X2O 10k lb winch
Synthetic winch line
Factor 55 thimble
EVO Mfg full skid plates
EVO Mfg Evap skid
EVO Mfg RockSkins
EVO Mfg weld on rock sliders
Poison Spyder rear Crusher Corners
AEV Frame mount Tire carrier
ORO License Plate relocation kit
Rigid Industries Dually Rear Flood Lights
Rigid Industries Dually A-pillar spot lights
8 LED under carriage rock lights
Custom high clearance Dynomax Exhaust
Firestick 3’ CB antenna
Antenna X low profile radio antenna
Interior:
Alpine Sound System w/ Navigation
Cobra WXST 75 CB radio w/ mount
Switch Pros system for electrical accessories
Genright weld-in Full Roll Cage
Black Leather
Smittybilt Molle Bag Carrier on tailgate
LED interior lights
Drake quick release fire extinguisher mount
5lb fire extinguisher
Other:
ARB Twin Air Compressor mounted under hood
All breathers from axles and tranny extended up high
6 Speed manual transmission
AEV procal module includes to reprogram computer based on mods
Spiderweb shade full mesh top
I modified the soundbar to fit the cage as well as all the interior trim pieces. The cage install has a very clean look.
Hard Rock Edition
68k miles
Front Axle:
Rear Axle:
Stock D44 housing
Wheels and Tires:
Fox 2.0 shocks
Synergy Track Bar
Synergy Drag Link
Factor 55 thimble
EVO Mfg Evap skid
EVO Mfg RockSkins
Interior:
Black Leather
LED interior lights
Other:
