2008 Jeep Wrangler (Purchased August 2012)
42,257
-Bosch MircoEdge Wipers 40715 @ 42848 8/11/12
-Added Prestone Extended Life Coolant @42843 8/11/12
-Banks Ram Air Intake @43106 8/16/12
-Rampage Billet Black Fuel Door Cover @43106 8/16/12
-Rugged Ridge Floor Mats Front @43106 8/16/12
-Rugged Ridge Door/Glovebox Handle Cover Kit @43106 8/16/12
-303 Aerospace Protectant Wipes Applied (Top, Bumpers, Fenders) @ 9/1/12
-AntennaX 13” Rubber Antenna @43964 9/4/12
-Nitto Terra Grappler 285/70R17 Tires @43970 9/6/12
-Rough Country 2.2 Steering Stabilizer w/ Relocation Bracket @44590 9/13/12
-Wade In-Channel Smoked Vent Visors 2 pc @47111 11/8/12
-Oil Change Mobil 1 5w30 Full Synthetic @47128 11/9/12
-Mobil1 Oil Filter M1-102
-Drain Pan Bolt w/ Gasket
-Drilled Holes In Door Handles and Mirrors @47128 11/9/12
-Rock Krawler 2.5” Stock Mod System @50700 4/12/13
-RK Front Sway Bar Extended/Disconnect Links
-RK Front and Rear progressive coils
-RK Double Adjustable Front Track Bar
-RK Rear Track Bar Relocation Bracket (Needs Weld Still)
-RK 2” Front and Rear Bump Stops
-Bilstein 5100 Shocks Front and Rear @50700 4/12/13
-Front: 24-186872 (x2)
-Rear: 33-186887 (x2)
-Crown 0-6” Stainless Steel Brake Lines Front and Rear @50700 4/12/13
-Crown 1.5” 5x5 Wheel Spacers Front and Rear (Red Loctite) @50700 4/12/13
-DynoMax Evolution Competition Exhaust #39516 (Cut 2.5”) @50700 4/12/13
-Mopar Tinted Soft Top Window Kit (30%) @50700 4/12/13
-PlastiDip Stock Wheels Black (x5) @50740 4/16/13
-Oil Change Mobil 1 5w-30 Full Synthetic @50785 4/20/13
-Mobil 1 Oil Filter M1-109
-Windows Tinted 35% @54500 6/20/13
-Bosch MicroEdge Windshield Wipers 40715 @ 54890 6/29/13
-Custom Cargo Trunk Floor Mat @ 54890 6/29/13
-Duralast Idler Pulley @55139 7/21/13
-Duralast Serpentine Belt @55139 7/21/13
-Oil Change Mobil 1 5w-30 Full Synthetic @55139 7/21/13
-Bosch 3422 Oil Filter
-New Drain Bolt w/ Washer
-Autolite Platinum Spark Plugs (gapped .050) @55139 7/21/13
-Removed Exhaust Heat Shield @55139 7/21/13
-Rotated Tires @55139 7/21/13
-Oil Change Mobil 1 5w-20 Full Synthetic @58135 9/30/13
-M14-1.50 Drain Bolt w/ Washer
-Fram CA10348 Air Filter @58135 9/30/13
-Alpine CDE-143BT @58135 9/30/13
-Optima Yellow Top Battery @58200 11/23/13
-Dana 30 JK Front Carrier Case (3.73 Up) @58273 3/11/14
-Lube Locker Dana 30 Differential Cover Gasket @58273 3/11/14
-Lube Locker Dana 44 Differential Cover Gasket @58273 3/11/14
-Nitro Gear 4.88 Package (front/rear) @58273 3/11/14
-EVO MFG Rock Star Skids/Relocation Brackets @58273 3/11/14
-TeraFlex Dana 30 Differential Cover @58273 3/11/14
-TeraFlex Dana 44 Differential Cover @58273 3/11/14
-TeraFlex Front Axle Sleeves @58273 3/11/14
-TeraFlex Front Axle Gusset Kit @58273 3/11/14
-80/90 Front/Rear Diff Fluid @58273 3/11/14
-OE Tranny Fluid @58273 3/11/14
-TeraFlex Rear Sway Bar Extended Link @58273 3/11/14
-Oil Change Mobil 1 5w-20 Full Synthetic @58273 3/11/14
-Mobile 1 M1-102 Oil Filter
-Goodyear Wrangler MT/R Kevlar 37x12.50R17LT 124Q @58350 4/18/14
-ATX Slab Beadlock Wheels 17x9 (x5) @58350 4/18/14
-(Removed) Crown Automotive 1.5” Wheel Spacers @58350 4/18/14
-(Removed) Rubicon Wheels and Nitto Terra Grappler Tires @58350 4/18/14
-ACE Engineering Pro Series Rear Bumper w/ Tire Carrier @58365 4/19/14
-Lifetime LED SR (x2) 7.6” Light Bars @58365 4/19/14
-Vector Offroad Tailgate Plugs @58365 4/19/14
-Superchips FlashCal @58365 4/19/14
-ACE Engineering Pro Series Front Bumper w/ Bull Bar @58365 4/20/14
-Lifetime LED SR 21.5” Light Bar @58365 4/20/14
-ACE Engineering Wide Tubular Fenders @58365 4/20/14
-ACE Engineering Bolt-On Rock Sliders @58365 4/20/14
-ACE Engineering Rotopax Can Mount @58365 4/20/14
-Mopar Rubicon Take-Off Sliders @58365 4/20/14
-Rugged Ridge Hood Lock @58365 4/20/14
-Offroad Elements Superior Grill Mesh @58365 4/20/14
-Sprayed Underbody w/ Bedliner @58365 4/20/14
-Truck-Lite LED Military Self-Defrosting Headlights @58365 4/20/14
-Trek Armor Seat Covers @58375 4/21/14
-ACE Engineering Cargo Basket @58375 4/21/14
-Spiderwebshade JK-1 2D @58375 4/21/14
-ARB Air Compressor @58375 4/21/14
-Angry Offroad Power Distrobution Box @58375 4/21/14
-Quadratec Extreme Duty Battery Terminals @58375 4/21/14
-6 Switch Panel @58380 4/22/14
-OTRATTW Switches Installed @58380 4/22/14
-Rock Lights
-Windshield Light Bar
-Front Bumper Light Bar
-Rear Bumper Lights Bars
-Air Compressor
-Kicker 40CS654 6.5” Coaxial Speakers Front/Rear @58400 4/24/14
-PSC Fire Extinguisher Holder @58400 4/24/14
-Rear Axle Breather Hose Extended @58400 4/24/14
-Smittybilt D-Rings On Bumpers Front/Rear @58400 4/24/14
-Vector Offroad UFOs Hood @58400 4/24/14
-Rock Hard License Plate Relocation Kit w/ LED Light @58400 4/24/14
-MOPAR License Plate Delete Plug @58400 4/24/14
-RECON 10500 Waterproof Winch @58545 4/25/14
-Synthetic Line
-Wireless Remote
-10’ Tree Saver Strap
-Snatch Block
-x2 D-Rings
-Waterproof Cover
-ACE Engineering Winch Plate Mount @58545 4/25/14
-PSC Aluminum Hawse Fairlead @58545 4/25/14
-Factor 55 Pro Link (Red) @58545 4/25/14
-Factor 55 Winch Lock @58545 4/25/14
-Rugged Ridge Tow Harness @58545 4/26/14
-Hopkins Mag-Flat Magnetic Harness Bracket @58545 4/26/14
-Smittybilt Tailgate Cover @58545 4/26/14
-Rugged Ridge Aluminum Hood Latches @58545 4/26/14
-Bilstein Steering Stab. @58545 4/27/14
-Syngery Steering Stab. Clamp @58545 4/27/14
-Cobra 18wx II CB Radio @58545 4/27/14
-Fire Extinguishers Installed (x2 front/rear) @58545 5/2/2014
-Daystar D-Ring Isolators (x2 pairs) @58545 5/2/2014
-ARB Medium Recovery Bag @58545 5/2/2014
-Oil Change Valvoline Full Synthetic 5W20 @63255 6/26/2014
-Goodyear 21348MP Oil Filter
-Tires Rotated (all five) @63255 6/26/2014
-OEM Black Jeep Front Emblem @63300 7/1/2014
-Rockridge LED Conversion Taillights @63300 7/1/2014
-Plastidipped Front Grill Black @64000 8/7/2014
-Lucas Heavy Duty Gear Oil Change 85W140 @65176 8/23/14
-Front D30/Rear D44 Diffs
-Lucas Heavy Duty Gear Oil Change (rear diff only for inspection) @64550 10/9/14
- Bosch MicroEdge Windshield Wipers 40715 @64550 10/9/14
