CascadeUnlimited
I'm installing the 2.5" OME on my 2015 JKU and ran into a problem with the JKs adjustable rear sway bar links. I sized the links per instructions, installed on the outside and now the top is rubbing hard on the tires now. In one way it makes sense as the axle is farther from the frame, keeping the sway bar relatively parallel to the ground, the ends will sit higher relative to the tires. That said, I sure wasn't expecting that.
