I've finally decided to get a 12 JKU Rubi. I'm going with the automatic trans. The one thing that I'm not sure about is, which factory rear gears to get. I would like some input from you guys. Thank you in advance. My apologies if this is a dumb question.
CDL
4:10s is whats standard on most the rubicon's and thats what you want; with that you can easily run up to 35s. Check the sticker on the ones you like it will say the ratio. And you say "what rear gears" like it can be different from the front diff but it doesn't work that way on a 4wd vehicle the front will be the same. They call it rear gears on the website because there are 2wd wranglers :naw: but rubi's are 4 wheel only.
You know the old saying, "There are no dumb questions" it definetly applies to Jeeps. You should ask first and this forum is a good place to do it. Not your
Jeep salesmen, they probably know less about the product they are selling than you (usually true).
Like Kern said, 4:10 is the
option to go with if you are going to mod for off roading. You will probably end up with larger tires and the gears will help. I have 3:73s but it's my daily driver and I'm sticking with 32 inch tires and I can still take mine off road once in a while and hang with most of the guys (and girls). I tell my self I'm getting a little better mpg's than the JK's with 4:10's and big tires, but that's probably only a little true.
Decide first what you are going to do with your JKU, then buy/option it the way that will suit your needs.
