Weebz
So I got some new ATX slabs with 37” Cooper SST Pro. My issue is I’m not confident on the seat of the rear bead. Does this look right? I never got that pop of the bead setting.
Yup, looks right to me :yup:
I know you Eddie have been doing this much longer than most of the people on here and not trying to question either one of you guys, but if you look at the second picture.. Doesn't it look like it's not seated all the way yet? In the first picture it looks okay but the second picture it just doesn't seem like it's correct?
Appreciate. All mounted up. Throwing them on tomorrow.
I watched the EVO video on how to mount these. I still don't how you guys get a STT Cooper to fit onto an ATX wheel by hand. I spent an hour with soap/water mix trying to get a tire on. I tried jumping on it. I tried a hi-lift jack and weight of the jeep. I tried a 4' pry bar (don't recommend it, it nearly took me out when it popped loose). I ended up with the tire jammed halfway on and had to trailer the whole mess to a tire shop. I'm already nervous about replacing the tires when they're worn out.
Here's how far I got when I got defeated. lol.
The Coopers are TOUGH! When i did my Slabs and Coopers, It took 3 of us longer to pull 5 tires off and put the Slabs on 5 Cooper STT pros than it did to pull front and rear Rubi 44 out and install PR44 and PR60SF on another jeep.
Very possible could have been. Maybe if I supplied more snacks and beverages they would have been more motivated.Maybe the problem was your helpers? [emoji848][emoji23]
Very possible could have been. Maybe if I supplied more snacks and beverages they would have been more motivated. [emoji848]
You only started to sweat when the pizza delivery lady showed up!
This is true ^^. I watched Mel's video 50 times trying to see where he threw the magic pixie dust on his tires to make it look so easy. I PM'd Eddie like 20 times asking what I was doing wrong. Those Coops are a bitch man. I'm probably gonna just cut mine off like Overlander said.The Coopers are TOUGH! When i did my Slabs and Coopers, It took 3 of us longer to pull 5 tires off and put the Slabs on 5 Cooper STT pros than it did to pull front and rear Rubi 44 out and install PR44 and PR60SF on another jeep.
