Mybadjk
Yes and no. The 05+ has 35 spline outer stubs but require a TON more work and will also be 8x170 bolt pattern. The 04 and down have 30 spline outer stubs, can built a lot faster and easier, and will be 8x6.5 bolt pattern. If someone wants me to build them a set I recommend going with the 04 down axles and installing be Dynatrac free spin kit. This does a few things.
1) Eliminates the unit bearing
2) Keeps the stock ABS tooth count so you can continue to use a ProCal if you want
3) Gives you a 35 spline outer
Yeah the cast on the new ones are a bitch. Found a guy that sells them with them cut off for a great price. You have to change the outer stub for the dynatrac free spin kit? I didn’t know they made a kit. I knew Currie did.
Nvm Currie is unit bearing. Saw the dynatrac kit is 1800
