Rooster jk
Keep us updated.....im about to get a ram setup from them.
Got it back on jackstands and it steers both directions but it is not even as easy as when it had stock steering. Could there just be a ton of air in the system still? Definitely still harder to steer to passenger vs driver side.
Sounds like you might have an airlock in the system. Personally I would put some road miles on it and let it self bleed.
I mentioned it before but with the RR you will have slower steering than stock at idle. The pump doesn't output enough to move the ram faster than the sector shaft.
If you throw in a PSC pump, it will solve that issue for you. My experience on the rocks, although it is slower to steer when stopped, it is never hard even locked up.
Hope you get it figured out. I've been really impressed with the kit so far.
here it a routing diagram I made off my PSC -you may not have all the components but the routing should be the same:
have you checked to make sure some part of the ram isn't hanging on the diff cover? steering should be easy in both directions.
does the steering get easier with higher rpms?
make sure the front end is lifted when you bleed the system.
what components do you have? ram, reservoir? stock pump? cooler?
also possible you may have some debris blocking a port in the steering box.
make sure there are no sharp bends in any of the hoses, there should be radius bends
the advantage of having a ram is when you are on the trail, if it's as hard to steer than you may as well stick with stock.
I can steer mine in 4Lo, lockers locked just as easily as I can when normal driving.
PSC has bleeding instructions on their website if you're not already using them.
have you tried cracking the lines at the piston ? with the jeep on jack stands and Turing the wheels side to side like 10 times , I work on a lot of heavy equipment that uses ram assist on steering and that how I bleed the piston just make sure you have enough fluid in the reservoir as you will loose some as it bleeds out
One thing I completely forgot to ask you. Did you center the steering box before installing it?Well I took the rig out for a drive and it turns left with one finger but does not want to turn to the right without serious pressure on the steering wheel. Really perplexing. Not sure if air is the issue or not.
Yep. Sure did. Turns full lock both directions on jackstands but much harder turning to the right.
starting to sound like the box got ported wrong. :thinking:
Weird. I'm clueless at this point, sorry man.
WTO should help you out though, let me know what they say as I'm curious myself.
From what I’ve learned you can never disconnect the ram and expect it to operate with the steering wheel.
Doubtful that they ported it wrong but I suppose it can happen. I’m willing to bet that your pump was doing just about all it could before this and now the added work of a ram has probably pushed it to its limit. Hopefully you get is resolved soon.
I will tell you though that hydro-assist is one of those things that nearly every person has a different opinion on how it feels. In other words, it’s subjective. Once you get things worked out give it about a week of driving it to get used to the new feel.
All of this^
The ram (disconnected from the tie rod) should reach full travel well before you reach full lock on the wheel. that said, it should be moving in the Correct direction (For a conventional setup it should be extending when turning driver, contracting when turning passenger, etc)
I have no experience with running a factory pump with a ram, But I know Jackal01 ran his ram setup with the factory pump for a short while, he quickly opted for the PSC high flow pump upgrade.
Correct. My pump has 87k miles/6 years on it running 35s and 37s since buying it with 40k miles. Without the redneck ram on but using the modified gearbox the steering is "fine' on pavement. Ram attached, different story. After a wheeling trip a couple weeks ago one of my lines got messed up and I had to remove the ram and hoses as I thought the delay-sensation was due to the line getting pinched so not enough fluid is flowing. Ordered new hoses, put everything back together. Nope. Problem persisted. Having talked to a couple people we all agreed that more than likely the pump is not able, any longer, to keep up with the ram. The sensation is difficult to describe. Going slow, like 10, it isn't too noticeable if at all. When moving faster I would turn the wheel and it would take a fair amount of force to turn, then a second later the tires would turn. Turning back opposite would take another second. There would be no way to properly do a serpentine course essentially as the steering is "delayed" and force needed is more than what anyone would want. I was able to drive freeway speeds but it was uncomfortable. Hopefully the PSC pump and reservoir solve this.
