The BAD Influence
Please ignore the RC dual SS. I put that on prior to joining this site.
A few weeks ago I removed the relocation brackets and installed adjustable CAs. I've always noticed the front tires sat over to the passenger side too far. While finishing up the CAs I took the time to actually measure how far off the front axle was. It was 3/4 inch off.
A couple weeks ago I tried to adjust where the track bar attaches to the bracket. (Stock, non-adjustable track bar. The Rubicon express kit came with a track bar relocation bracket and drag link flip). There's only four adjustments that can be made; up, down, left or right. By adjusting the attachment location, it pulled the axle to perfect center. However, since that time (I did adjust the CAs and draglink after making the track bar adjustment. 4° and bottom lengths are both equal, top as well) it feels like at any moment we're going to go into death wobble. Between 40-50 mph the feeling is the worst, but at almost any speed, a bump will really get my heart racing. Based on what I'm seeing, the drag link and track bar are not exactly parallel. Given that I can only adjust the track bar at the attachment point, I'm wondering if I installed an adjustable track bar and then attached it higher if this would fix my problem.
Thank you for any ideas or suggestions.
Sent from my XT1585 using WAYALIFE mobile app
