I just never seen the rock hards with a hole for the oil drain, only the little trap door.The bottom picture is taken right from ROCK HARD'S web site, so I doubt they are Metalcloaks.
Also I have the same set of skids on my JK.
Sent from my SM-G955U using WAYALIFE mobile app
I'm pretty sure the bottom one is the Metalcloak skids.
The bottom picture is our skids, but the previous design. We changed to trap door a few years back.If I'm not mistaken, they used to have the hole, but moved to the trap door in later skids. Mine are about a year old, and have the trap door.
Why would you want an oil pan skid plate that mounts directly to the oil pan instead of around it. Every time your skid takes a hit does not also the engine thats mounted to the skid? Just a thought.
Hi,
I run the RIVAL Skid Plate on my JK. I'm quite happy with it. It's solid and you have a service opening so you don't need to unbolt the whole skidplate if you cange the oil.
Lg
With our skid plate yes.Can I run the long arm Skid (Of either RockHard or EVO) If I think I'm going to run the Long Arms in the future. Thanks
Any one heard of the snyper skid plates from westin automotive? Bolt heads kinda stick up but one sure you could do something else to work. Saw them on a steer smarts build looking pretty nice epically for mud.
Sent from my SM-G920V using WAYALIFE mobile app
A couple guys tried pimping them here a while back. Never heard much more than that:
https://wayalife.com/showthread.php/45568-Westin-Snyper-skid-plate
And Steer Smarts still sucks balls:
https://wayalife.com/showthread.php/34385-STEER-SMARTS-has-been-Removed-from-WAYALIFE
