Kenthejeepguy
So I like my Smittybilt drawer, it has helped a lot, but I'll be watching for good ideas from you all. I want to avoid a roof-top carrier but may have to go that way. Sent from my iPhone using WAYALIFE mobile app
Well ain't that just nifty! I like how it's just a shelf that doesn't cover the whole back end and allowing for bigger things to be stuffed back there if needed. Nice touch on the notch on for the fridge too :thumb:
I picked up the Smittybilt drawer also. It works well for carting tools and recovery gear. I glued rubberized shelf liner on top and use a bungee net to hold things secure on top. No floor mounted sub woofer on my Jeep so I didn't need to worry about keeping room for that.
I stole a mounting idea and have it hinged in the back so I can tilt it up to get access to the small storage area where the jack is located.
So it's just attached in the back with the hinge? Any pics of it tilted up? Probably wouldn't be worth it, but a set of gas shocks to lift the box would be handy.
Hi Journeyman.
Here's a shot of the box tilted up and access to the JK storage area.
Rt on dude. That's awesome [emoji1376] probably not very convenient if your loaded down with gear. But definitely a great stash spot for all the shit just hit the fan type gear.
Thank you for the pic. I love seeing all these different options. Gets me thinking about my setup and how I can improve on it.
So with your quart holder on the right are you still able to access the storage panel under it?
No. Two pretty beefy gate hinges on the back attached to the floor then one bolt on the inside into the floor.
When I get out of work and get home if I think of it I'll tip it up for you and take a shot. And you're right, not too much to it. When I saw it on another storage drawer I thought it would be cool to do something similar so I didn't need to lose the little storage for the jack and other little stuff.
Here's what's going on in my rear....
How many fucking threads do we need on rear cargo storage ideas?
Only when I fold the rear seat down. Through bolted the holder to the arb steel frame.
Got it!
I have the same storage unit and I like how you mounted your fluids.
Stealing it!!!
:beer:
Why would you want to carry fluids? :idontknow:
