Majik
A little different line of questioning:
About to purchase my 37s. While deciding on which tire, I compared specs on a bunch and noted drastically different weights. Obviously influenced by # of plys, load rating, etc. Here's an example:
MTR Kevlar 37x12.5x17: 73 lbs
Mickey Thompson MTZ: 84 lbs
Toyo Open Ctry MT: 94 lbs.
I've personally run the MTR and the Toyos in the past. Looking at this from an overall driving standpoint, 21lbs of extra rotating mass per wheel is a crap load!! Brakes, ball joints, acceleration, etc all affected. The jeep is the lightest vehicle with the smallest engine ive ever put 37s on. Considering that, my questions to the crowd are:
1. Does anyone regret running the toyos (or any 90+ lb tire) on a vehicle with limited power to really spin them a bit when you need to jab the gas a little?
2. Has anyone here had two different sets of 37s (say, MTRs and then Toyos) on their rig where you can speak from personal experience on how the 20 lb tire weight difference felt when you changed tires?
3. Is the Jeep heavy enough to flex an E-load rated tire well when aired down? (If, like with the Toyos, E rated is the only option in a 37)
I loved my Toyos in the past... and I'm trying to upgrade everything on the Jeep to reliably run 37s pretty hard... I'm just curious if anyone else has paused to recheck their tire choice due to the weight issue? 20 lbs extra spinning (or 80 lbs when locked) is a lot of extra mass.
If the answer is simply "the extra weight, loss of power, loss of braking, etc is offset by a massive durability increase..." then I can respect that.
. Just thinking out loud here...
