Diff fluid capacity with grizzly locker
Jeepwave
Having a hard time finding advice for how much diff fluid to add to the rear d44 with my grizzly locker installed. I'm assuming the capacity should change slightly with the locker installed? I'm running 4.88 gears with a grizzly locker. Poison spyder bombshell covers.
Regardless of what you're running inside, you want to have as much fluid as is necessary to have it sit at about the base of your axle tube. If you're running a factory differential cover, you should be able to fill the housing till is starts to ooze out the fill hole. If you're running an aftermarket cover with a higher fill hole and/or have your pinion angle set in line with your drive shaft, you can always use a zip tie as a dip stick to verify your level. All that being said, the factory amount is more than likely what you'll need.
