quertyman
If you look at the race cars with the coilovers through the tub you can see that it's like that in order to fit a longer shock in there. More down travel without losing any up travel. If your jeep can handle a 2" bumpstops without rubbing tires but your shocks can't, a raised upper shock mount would allow that shock to not bottom out and have more droop than a shorter shock would. Instead another solution is just add more bump. This is exactly what situation my jeep is in. I value that up travel because of the way I drive when it comes to the streets, hills, desert etc.Must be missing something. I've read hundred (thousands?) of Jeep suspension posts over the past few years now. I don't recall anyone else have a shock that's too long, needing to relocate the upper mount.
The obvious question I'm missing is, What are you attempting to achieve that demands you use a shock too long, that you cannot just get a shorter shock? At the end of the day, is the extra inch of droop this might deliver (lost if you hike its mount point) really going to improve your off-road ability?
Now I'm sure he doesn't want to replace his shocks just to get the rockstar skids, but if there was a way to raise the upper and lower shock mount the same height, than no suspension geometry would be changed.
EDIT: Just did some research and found that synergy makes a replacement upper and lower rear shock mount with skids on the bottom. The upper mount gives you a 2" higher shock mount while the lower gives 1 3/8. OP why dont you just pair those two products together? They were made for each other and it looks like the lower one has an increase of 1.25" ground clearence vs the evos 1.5" of ground clearence.
