Brake line fitting question.
VeruGE*144
Should this fitting at the end of the hard brake line be spinning freely on the line? From some videos and write ups I've seen it should. Mine is stuck and I don't want to put to much pressure on it so I won't kink/break the hardline.
Any ideas?
Any ideas?
Yes it is suppose to spin freely. Spray some on blaster on the top side of it to help lube and loosen it up
It's probably not spinning because the hard line is a bit bent a bit. When you attach your soft line to it, hold it in place with a wrench and then use a flare nut wrench to tighten the nut.
Agreed with Eddie. Looks like the bend is keeping the fitting from spinning. A light bend back won't hurt anything. Most important: when you hook that line up, make 100% sure the threads go in correctly. If not, you're totally screwed.
I tried both pb blaster and flare nut wrench. The fitting won't budge, it's twists the line. Ugh.... that's so annoying. I really don't want to break the hard line. Anybody has any other ideas? I would greatly appreciate any advice on this.
Again, the slight bend in the hard line is more than likely what's keeping the nut from spinning. If you do most of the holding with a wrench on the larger soft line end, you should be able to free up the nut. Really, the worst that can happen is that you do damage/break the hard line and that can be easily fixed with a flare tool.
Isn't it a double flare or something? I'm drawing a blank on the correct term
Any luck?
Wasn't planing on learning how to use the flare tool today but I am glad I did..... now I know more than I did before I started. Couple trips to auto store, one broken fitting, cut the factory line twice and one side is done lol. I managed to manipulate the factory brake line to get me enough to make a connection. I also learned the hard way something that I already knew, brass is really soft metal and you can't just grab it with a pair of pliers when it gets stuck on the line....
Thank You Eddie [emoji482]
Wasn't planing on learning how to use the flare tool today but I am glad I did..... know I know more than I did before I started. Couple trips to auto store, one broken fitting, cut the factory line twice and one side is done lol. I managed to manipulate the factory brake line to get me enough to make a connection. I also learned the hard way something that I already knew, brass is really soft metal and you can't just grab it with a pair of pliers when it gets stuck on the line....
Awesome, you just learned something yourself a useful skill and something you will use again in the future :thumb:
Wow. Good for you for doing that yourself. Glad you got it working.
Am glad I did it myself, at least I have a piece of mind now. I know why, and most importantly HOW it was done. I also ended up flushing my whole system. Finished about an hr ago, other side gave a little different set of problems. I will post a summary of this job later on today or tomorrow morning, hopefully somebody can relate to this in the future. Now am just enjoying couple victory beers [emoji854]
Well done man!!!!!
