desertrunner
Has anyone tried to set up a pr44 / SF pr60 combo on essentially a stock jk suspension?
I'm pretty close to being able to put in an order with dynatrac but I am trying to plan ahead a little with issues I might run into trying to get these axles set up on my 2dr that is sitting only on 4dr springs and shocks everything else is stock.
If I order the standard pr44 front housing everything should be the same as the stock axle geometry and I'm assuming it can swap in with little issue minus maybe the stock drive shaft that I'm not sure I can re use with the pr44.
If I go with the SF Pr60 rear I know I will at a minimum need a new rear drive shaft but not sure if I can get away with the stock control arms.
Anyone have some insight with setting these things up on a stock suspension?
