WJCO
Meme King
Could be, but I,ve replaced all the calipers with new ones....Last summer i had a brake line failure near the steering box, rubbed thru,,,,since then the brakes have been fubar...As with all my jeeps, brtween 100k -125k I replace all brake /fuel components...
I guess it could be possible the new line could be sucking air, but no where is it showing external leakage...the solus pro did require a bleed down on the rightside twice both frt and rear.... I've bled just about a full gal thru the system the old school way, then a reverse bleed, hcu bleed with the solus then back to a maual bleed.. I'll find it one way or the other....
Thanks for the input....
I would spray soapy water on one connection at a time and have someone stand on the brakes and try to find the leak. Tricky thing is that you don't want ANY water to get in the brake system, so if you are sucking air somewhere, you don't want the soapy water solution getting in there.
If you are at a stop with your foot on the pedal for a long period of time, does the pedal slowly fade down.
